Print at Oct 5, 2026, 6:15:04 PM
Posted by Keet at Aug 5, 2022, 8:39:38 PM
Re: Need Pro-Help!
For the square hole in the shelf you can export a box with the size of the hole and import it as a staircase. This will cut the hole in the room you created after following what hansmex suggested. Then select only the room for export and it should keep the hole.
