Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Room Area (Meters Squared) Incorrect? » » » » Post: Re: Room Area (Meters Squared) Incorrect? |
Print at Oct 1, 2026, 4:51:50 AM |
| Posted by Puybaret at Apr 1, 2010, 5:51:10 PM |
Re: Room Area (Meters Squared) Incorrect? Walls length is measured in their middle, so the area of a room depends on the thickness of the walls that surround it and the way you create that room. If you have only one room, I suggest you to create first the room with the keyboard (press the enter key after choosing the first point of the room), then select the Create walls tool and double-click in the room to create the walls around it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 4:51:50 AM |
