Print at Oct 8, 2026, 12:01:54 PM
Posted by Keet at Aug 17, 2022, 10:52:49 AM
Re: double cut out for windows
The only way I know of is by manually changing the cut-out. This can be done by importing your window in a furniture library using the
Furniture Library Editor. Using that editor you can modify the cut-out which is defined by a SVG path.
This Guide for SVG Path cut-outs by OKH is very helpful to get to understand how to do that. It should be possible to have multiple cut-outs before the closing "z" in the SVG path definition but you might have to read a few other sources about SVG paths.
