Print at Oct 6, 2026, 12:45:50 AM
Posted by hansmex at Aug 18, 2022, 11:55:38 AM
Re: how to draw curved upwards wall?
Workaround:
- draw a straight wall (doesn't work with curved wall)
- import a cylinder and mark it as Door/Window
- insert the cylinder in the wall at the correct elevation and size
- make the cylinder invisible (cutout will remain)
[img]https://www.mediafire.com/view/b74wryub5...urved_wall.PNG/file[/img]
Notes
- SH3D can make a curved/round/oval cut-out in a straight wall; in a curved wall the curved part will be circumscribed by a rectangular box
- most/many cylinders/circles are described as a set of straight lines; for a good result you need a cylinder that is composed of many small parts (or even a real circle); (see image for curve with angles)
