Print at Sep 23, 2026, 5:07:31 PM
Posted by Puybaret at Aug 19, 2022, 3:26:39 PM
Re: Select Hide Utility plug-in
I just tested the last version and it doesn't work when there is no level in the home, with the following exception:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.eteks.sweethome3d.model.Level.isViewableAndVisible()" because the return value of "utility.SelectHidePlugin.access$6(utility.SelectHidePlugin)" is null
at utility.SelectHidePlugin$1.execute(SelectHidePlugin.java:108)
Dorin, I hope this will help you to fix this bug.
