Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 27, 2026, 9:30:48 PM |
| Posted by dorin at Aug 28, 2022, 7:54:21 PM |
Re: Generate roof plugin I'm glad to see here someone closer of my age (well, also more wiser than me). Don't expect too much from me. Let's start: You've send me this: ![]() If You send the sh3d file maybe could be easier. Anyway I put it on background and I've try to understand what was in Your intentions I suppose this could be the base structure. ![]() Hiding the background, remain this: ![]() I use Auto Dimension plugin to generate roof projection. (not mandatory) ![]() The result is this: ![]() It's not quite useful but it's a start It appear You want to make a house from round wood, so, You have to adjust the roof projection probably something like this, by deleting unnecessary points from room ![]() Now, with room selected, Tool->Generate roof... ![]() Well, here are at least two variants: 1. simple hipped roof Press Ok ![]() Modify texture ![]() 2. Something like gabled roof Select triangle faces and set angle at 90 dg ( or what ever You want) ![]() After press Ok ![]() Set texture... ![]() Select some faces and mark them as invisible ![]() Could be something like this ![]() Of course You could make it better. Good lack! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 27, 2026, 9:30:48 PM |
