Print at Oct 15, 2026, 10:53:22 AM
Posted by yafeng at Apr 10, 2010, 12:04:33 PM
Re: Making (parts of) walls invisible
@Hans: right, it works after "Door or window" option is selected.
However, this still won't solve my original problem. My original problem is how to put two windows, which are vertically overlapping on the same wall. I tried one trick you mentioned, meaning export and then import a window without checking "Door or window". However, such a window, after putting to wall, does create the see-through part, meaning it's just a window attached to concrete wall.
How could I solve that problem? I also tried multi layer walls. It works. However, after I aligned one wall on top of the other one, the two walls don't look like one piece, the brightness or something is different. Wierd thing is, the two walls look fine in camera view after rendering.
