Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Window opening directions » » » » Post: Re: Window opening directions |
Print at Oct 5, 2026, 7:10:31 PM |
| Posted by Keet at Oct 17, 2022, 8:23:59 AM |
Re: Window opening directions This is a useful method if you want to use windows to make a conservatory but without all of the window openings. If you are creating your own custom conservatory I wouldn't use windows. Just create glass walls using boxes and glass. Your model will be smaller and without the unneeded opening displays.To create glass use a box the size of the glass you need. Export the box and name it "Glass.obj". Edit the Glass.obj and Glass.mtl files like this: Edit the Glass.obj file and replace "usemtl bottom", "usemtl top", "usemtl left", "usemtl right", "usemtl back", and "usemtl front" with "usemtl Glass". This should result in having 6 times "usemtl Glass" in the Glass.obj file. Save the file. Edit the Glass.mtl file and remove everything under the top comment lines (#), then insert this block of code: newmtl GlassImport the Glass.obj file and you have a Glass object that you can resize to any format. You can still change the color of the glass. You can use this same glass object for any other furniture you create that needs glass. You now also know how to change a property in existing furniture to glass. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 7:10:31 PM |
