Print at Oct 8, 2026, 8:46:03 AM
Posted by Keet at Oct 24, 2022, 8:09:37 AM
Re: Lean-to conservatory
... and I have used the principle of making the conservatory using walls...
I have not got to the roof yet. :)
There's more ways to Rome so if that works for you that's great.
A little trick for your roof if you are using standard windows:
You can't tilt windows because they are made to snap into a wall. But you can export a window and import it again as a regular object. Don't check the "Door or window" checkbox when you import. That way you have a window you can tilt for your roof.
