Print at Sep 29, 2026, 6:20:27 PM
Posted by Keet at Nov 4, 2022, 2:53:59 PM
Re: Project has gone blank
One possibility is that your 2D view is completely covered with the 3D view and it is in 'Virtual visit' mode where the camera is pointing away from your project.
Check what you see when you right click in your 'empty' window.
If the context menu starts with 'Aerial view' and 'Virtual visit' it's a 3D view window. Drag the top of that window down and your 2D window will appear. You are most likely in 'Virtual visit' mode where the camera is pointing away form your project so it doesn't show anything. Switch to 'Aerial view' and there's a good chance your project will appear. You might have to select a piece of furniture to center the view on it.
