Print at Oct 7, 2026, 12:03:41 AM
Posted by Keet at Nov 5, 2022, 3:12:04 PM
Re: Import From RoomScanLiDAR Levels Not Aligned
If I understand you correctly you have a level that is rotated according to one or more other levels.
If that is the case you can select everything (ctrl-A) on a level and use the rotate funtion that comes with the AdvancedEditing plugin. You can rotate with any arbritary angle and of course repeat it with all levels that need rotating. You might have to move everything too to get a correct line-up but that function is also available from the same plugin (main-menu icons are added after install of the plugin).
Mind you, the rotate function rotates everything selected: furniture, walls, rooms, polylines, dimension lines, etc. Exactly what you need.
