Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: New feature: Caption » » » » Post: Re: New feature: Caption |
Print at Sep 23, 2026, 7:44:57 PM |
| Posted by Daniels118 at Nov 5, 2022, 8:39:50 PM |
Re: New feature: Caption Hi Vasilij, you're right, the wirings are just [enhanced] polylines. To understand what it can be done and what cannot, we have to look at how SH3D works. Each class of object is stored in a distinct list member of the Home class: private List<HomePieceOfFurniture> furniture;The drawing is implemented in PlanComponent.paintHomeItems(...) by drawing each item of these lists: paintRooms(g2D, selectedItems, ...);Although the items in each list can be added or removed, there is no chance to add a new list to draw another class of objects. This means you have to resort to the current object classes. The Wirings and 3D dimension lines plugins work by extending one of the existing object classes (i.e. the polyline), by overriding the actual drawing code for the 3D view. This required some hack thich I'm not going to explain here. For your project I wouldn't use this approach, because basically you can use the current object classes without changing the drawing code. Let's call your new object "Caption", and let's see the difference with Wirings. The Wiring extends the polyline by adding a 3rd dimension to each point and changing the drawing code to handle 3 dimensions. The Caption is a collection of 2 objects: a standard Polyline and a standard Label. The caption doesn't need to draw a new type of object. It should only place a standard Polyline and a standard Label, and use event handling to enforce some rules, i.e. the polyline must always have exaclty 3 points, one attached to the furniture, and the other 2 attached to the bottom left and bottom right corners of the label; if the user moves the furniture, then the polyline and the label must translate with the furniture; if the user moves the label, then the 2 polyline points must move with the label. The offsets of the polyline and the label relative to the furniture must be saved in a custom property, so that you can keep it constant when translating. If the user tries to move a point of the polyline you should block it by forcing its position to the expected value. So the question is: how to know which furniture the polyline and the label belong to? It's easy: when you create the polyline and the label through the plugin, you also set a custom property on both objects, which is set to the id of the selected furniture. The text template can be stored in a custom property of the label, while the actual text of the label is computed by your plugin and updated from the template each time a change is detected in the properties of the attached furniture. This is how the "Link selected furniture" feature is capable of updating wirings position when the linked furnitures are moved around. You don't need to implement saving and reading of a new type, everythng you need are the custom properties which are already persisted. If you would follow this road, I would be happy to help you. But please be aware that I would only give hints and some code snippets, I'm not going to write whole pages of code for you (that would be matter for a paid work). You are free to copy as much code you need from the Wirings plugin as long as you respect the GPL license. Best regards, Daniele |
Current timezone is GMT Sep 23, 2026, 7:44:57 PM |
