Print at Oct 2, 2026, 2:26:13 PM
Posted by thomasmendozajr at Nov 10, 2022, 5:55:32 AM
Re: Stainless Steel Texture?
I find that scaling the textures helps a lot. When I make textures for my walls I set my texture pixels 512x1024 once I import it I'll get a warning message but I just keep the image unchanged. When I set the image perimeters I use a 4ft X 8ft when you cover your wall the texture looks crisp and covers the wall correctly. I will use a 1024X1024 pixel for the floor the bigger the pixels the more detail also the more memory your computer will need to support the larger textures but on a 1ft X 1ft perimeter the image looks really good. You can keep the scale at 100% just change the measurements of cover area.
