Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Magnetism cm instead of mm » » » » Post: Re: Magnetism cm instead of mm |
Print at Oct 5, 2026, 4:35:06 AM |
| Posted by Keet at Nov 10, 2022, 8:15:02 AM |
Re: Magnetism cm instead of mm hi, not quite. in other words: I would like to edit walls in cm steps with the mouse. in version 7.0 my mouse movement produces mm steps on x and y axis. 1cm steps would be much easier to handle. (or 0,5cm) Is there a way to set the x-y Grid to cm steps? You're probably the first one who asks for less precision You achieve exactly what you want with the zoom level as Emmanuel explained. Each mouse step gets bigger the further you zoom out. So zoom out and your steps get less precise, i.e. from 1mm, to 2mm, 0.5cm, 1cm, etc. The same happens for the arrow key steps, those too depend on the zoom level. A quicker way is to set the length with "Distance between endpoints" (wall property window). The wall stretches in the direction of the wall (the little arrows displayed on the wall). If you want to stretch in the other direction first reverse the wall direction (wall context menu). ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 4:35:06 AM |
