Print at Sep 24, 2026, 3:30:18 PM
Posted by Daniels118 at Nov 11, 2022, 7:17:11 AM
Re: Error "Could not create the Java Virtual Machine"
I fear SH3D isn't compatible with the latest Java versions, however if you use the SH3D installer version it comes with its own java bundle which should solve the problem. About memory allocation, you can overwrite the system-wide value for SH3D using a config file.
