Print at Oct 1, 2026, 3:28:32 AM
Posted by sjb007 at Nov 13, 2022, 3:26:26 AM
Re: camera back more and box on ceiling
If I understand what you are talking about, it is not possible to make the hollow. SH3D is not a true modelling tool, so you can't modify the mesh or do boolean subtractions.
You can either:
a) Use 5 cubes to create your recess. One a little higher in the center, and four around it to form the lower parts.
b) Use four cubes to form the lower parts and use the ceiling of the room as the recess (unless you are wanting to accurately lower that central area.
c) Use a proper modelling tool to edit your mesh and reimport it. (i.e. Blender)
