Print at Oct 1, 2026, 4:13:18 AM
Posted by Keet at Nov 17, 2022, 7:00:30 AM
Re: camera back more and box on ceiling
You can't create the same with walls since you can't elevate walls. But I don't see how the boxes hide showerheads or lights when you place them at the correct position and elevation.
In short, you don't 'mount' furniture to a wall, you position it so it displays as if mounted to a wall. Magnetism might suggest that you 'attach' it to a wall but magnetism is actually an auto-positioning mechanism. By moving/elevating your showerhead you should be able to position it so it looks attached to the box the same as if it were attached to a wall. Anything you hide with the boxes should be repositioned so they show where you want them.
