Print at Oct 3, 2026, 8:38:40 PM
Posted by Daniels118 at Nov 17, 2022, 7:23:54 PM
Re: Portable versions since 6.5 don't run on my Win10 PC
You could try to install this plugin that automatically redirects the console output to a file. Place it under "SweetHome3D-7.0.2-portable\data\plugins" folder.
The output will be stored in a file named "log.txt" within the application folder, it should be "C:\Users\YOUR_USER_NAME\eTeks\Sweet Home 3D", regardless you are using the portable or installer version.
If the program crashes before the plugin is loaded then it won't give any output, however it may worth a try.
