Print at Sep 24, 2026, 5:06:47 AM
Posted by Puybaret at Nov 23, 2022, 6:20:24 PM
Re: Generate roof plugin
Thanks, it works now.
The ApplicationPlugin.properties file is the default properties file for all languages and should contain all the properties you may use in the plug-in.
If you want to specify some different values for some properties like translation or special values for the English in the USA for example, you can create additional properties files with other suffixes like _fr or en_US, but you should not add new properties in these files.
