Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to calculate accurate dimensions? » » » » Post: Re: How to calculate accurate dimensions? |
Print at Oct 2, 2026, 12:19:27 PM |
| Posted by hansmex at Nov 26, 2022, 12:18:02 PM |
Re: How to calculate accurate dimensions? 1 - Mediafire changed its rules, it's now impossible to directly show the image, but the link works (if you copy it) 2 - You can't connect walls at a non-existing midpoint. To make this work proceed as follows: - use Split wall to divide wall A in two parts - Aa and Ab - use exact X,Y coordinates to position the split at the point where wall B should connect - make sure the wall directions are correct (suggestion: wall Aa and Ab go from left to right, wall B goes from down to up - select wall B, then wall Ab and use Join Walls to connect them H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 2, 2026, 12:19:27 PM |
