Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to calculate accurate dimensions? » » » » Post: Re: How to calculate accurate dimensions? |
Print at Sep 30, 2026, 11:46:08 PM |
| Posted by kawal at Nov 26, 2022, 2:25:09 PM |
Re: How to calculate accurate dimensions? 2 - You can't connect walls at a non-existing midpoint. To make this work proceed as follows: - use Split wall to divide wall A in two parts - Aa and Ab - use exact X,Y coordinates to position the split at the point where wall B should connect - make sure the wall directions are correct (suggestion: wall Aa and Ab go from left to right, wall B goes from down to up - select wall B, then wall Ab and use Join Walls to connect them I tried your solution. I was able to connect wall B and Ab and both got connected. However, I have two queries now: 1.Aa wall gets separated . is it not possible to make a T where all 3 walls are joined? 2.Inspite of splitting the wall at 3', it got splatted at 2'6" & 6'6" Please see the figure below Fig A - Original position where B was separate Fig B - Split was done at 3' Fig C - B and Ab selected Fig D - Join successful Fig E - Wall A got separated whereas i wanted a join of all 3 walls and another issue is that, 3' turned into 2'6" |
Current timezone is GMT Sep 30, 2026, 11:46:08 PM |
