Print at Oct 20, 2026, 3:43:06 PM
Posted by Keet at Dec 4, 2022, 11:36:00 AM
Re: ROOF WINDOW / VELUX WINDOWS
The rotation is a strange twisting motion, not the tilt of a velux. I suspect the window export of a snapped and rotated at import object is messing up that openable mechanism.
Most likely the export/import changed the direction of the hinge movement. It will take some experimenting but moving the "sweethome3d_hinge_1" string to a different side of the hinge part would solve that. I have encountered the same with hinges and changing the hinge side solved it.
