Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: The Display's Directional Conventions » » » » Post: Re: The Display's Directional Conventions |
Print at Oct 4, 2026, 12:24:11 PM |
| Posted by Puybaret at Dec 6, 2022, 9:00:06 PM |
Re: The Display's Directional Conventions one can rotate the 3D without affecting the 2D. What od you mean?So, understanding that the x-axis represents left and right, and the y-axis represents up and down, and that the zero on the layout is just a non-essential starting point, it appears that the missing component is the direction one is facing relative to the drawing If you miss it, just look at the 3D view!Does the x-axis need to be viewed from inside or outside? In other words, is the user facing a wall from inside so as to view the left and right directions, or facing it from the outside? He's facing from the top of the wall.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 12:24:11 PM |
