Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Translucent walls/panes with no reflection??? » » » » Post: Re: Translucent walls/panes with no reflection??? |
Print at Sep 29, 2026, 2:07:00 PM |
| Posted by NickDonato at Dec 15, 2022, 7:35:59 PM |
Re: Translucent walls/panes with no reflection??? Instead of playing with "d" MTL parameter, maybe you could try to use a half transparent texture. You could also try change the renderer quality to the highest level which render shiny objects with a more glossy effect. Puybaret, THAT'S PERFECT!!!... I found another thread that had semi-transparent png files to download, applied them as texture, and it works FANTASTIC!!!!! Thanks sooooooooo much for the great tip!!!!!! :D |
Current timezone is GMT Sep 29, 2026, 2:07:00 PM |
