Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 5:55:46 AM |
| Posted by dorin at Dec 29, 2022, 9:42:58 AM |
Re: Generate roof plugin You could use Autodimensioning plugin which have this option. Then you can modify the generated roof projection if is not exactly what you want. Probably you will encounter the same problem with unit measurement. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 5:55:46 AM |
