Print at Oct 12, 2026, 8:08:42 AM
Posted by hansmex at Jan 11, 2023, 6:28:58 AM
Re: 3D pictures rendering problem
Your model renders without problems on my PC.
Tips to render:
- in the Furniture List make visible the column Model Size.
- sort that column
- make the 6 largest models invisible - this reduces the file size with 140-150 MB
- read the FAQ where it says:
Under Windows, create a text file named SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe, write the maximum memory Java option in that file, for example -Xmx700m for 700 MB, then relaunch Sweet Home 3D. For a value higher than 700 MB, tested as the highest value under which Sweet Home 3D can run safely on a 32-bit Windows computer with little RAM, you should use a computer running 64-bit Windows and install Sweet Home 3D 4.3 or higher.
- allow SH3D as much memory as possible
