Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to create a flat 3D shape/a flat plate, but with more than 4 corners? » » » » Post: Re: How to create a flat 3D shape/a flat plate, but with more than 4 corners? |
Print at Sep 28, 2026, 2:16:21 PM |
| Posted by Mike53 at Jan 17, 2023, 10:25:03 PM |
Re: How to create a flat 3D shape/a flat plate, but with more than 4 corners? The room tool is the right idea, create it on a level other than ground floor, that way you will be able to set and/or adjust its depth. You can freehand the room or use walls, set at maybe 2mm wide and 2mm high to draw the shape you require. |
Current timezone is GMT Sep 28, 2026, 2:16:21 PM |
