Print at Oct 11, 2026, 5:28:30 AM
Posted by Puybaret at Jan 18, 2023, 10:13:33 AM
Re: No 3d display in "modify openings" dialog
It looks like a driver problem and I fear it will be very difficult to help you on this.
Maybe you could try to run Sweet Home 3D executable JAR with a more recent Java version, like Java 15 for example (with versions > 15, you'll have to add --add-opens=java.desktop/sun.awt=ALL-UNNAMED Java option in the command line).
To run it with Java 3D 1.5.2, you'll have to use also -Dcom.eteks.sweethome3d.j3d.version=1.5.2 Java option in the command line:
java -Dcom.eteks.sweethome3d.j3d.version=1.5.2 -jar path/to/SweetHome3D-7.0.2.jar
