Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Invisible walls - Light passing through » » » » Post: Re: Invisible walls - Light passing through |
Print at Oct 8, 2026, 8:45:33 AM |
| Posted by Daniels118 at Jan 20, 2023, 4:14:35 PM |
Re: Invisible walls - Light passing through To make the cutout the transparent box is imported as a window, and as a window lets light pass through, it is correct that light passes through the wall with this method. If your concern is about the sunlight coming from outside, you may set the time of the day to midnight in the photo creation tool, and light your home using only interior lights. If you need the sunlight for the outdoor and still wish to block this light through the cutouts, you may place some objects at specific positions so that they project a shadow right above the cutouts. |
Current timezone is GMT Oct 8, 2026, 8:45:33 AM |
