Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: 2D stairs » » » » Post: Re: 2D stairs |
Print at Oct 6, 2026, 7:47:39 AM |
| Posted by hansmex at Apr 21, 2010, 4:52:49 PM |
Re: 2D stairs Pilch: Your question isn't very clear. 1 - You can import a background image using Plan --> Import background image . 2 - You can use a picture of the desired staircase and import it as a texture. You can then apply the texture to a box with the desired dimensions. 3 - You can model the staircase in 3D (use boxes with height 0.1), and add the arrows (narrow boxes at 45 degree angles). Group your model, export and import it and you can even re-dimension it. I hope this helps. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 6, 2026, 7:47:39 AM |
