Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Weird 3D Artifacts » » » » Post: Re: Objets étranges en 3D |
Print at Sep 27, 2026, 8:56:37 AM |
| Posted by aminor00 at Feb 20, 2023, 6:20:28 PM |
Re: Objets étranges en 3D Thanks Emmanuel! 7.0.2i also works for me with my own files and the demos. I did notice some small "stutters" and strange white shadowing effect in the 3D View but I discovered I had left the "Overdrive" setting on "Extreme" on my gaming monitor. When I switched Overdrive back to "Normal" the shadowing went away, and the stutters seem to be much less. 3D view now doesn't seem much different from when I had a 1080Ti. HelonMead have you got a monitor with that feature? Can you set overdrive to "Normal" or "Off"? Otherwise I suggest you try uninstalling the AMD Adrenalin drivers using the AMD Clean Up Utility (https://www.amd.com/en/support/kb/faq/gpu-601) then re-install the drivers. Does that help remove the stutters? |
Current timezone is GMT Sep 27, 2026, 8:56:37 AM |
