Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Regarding FurnitureLibraryEditor and TexturesLibraryEditor. » » » » Post: Re: Regarding FurnitureLibraryEditor and TexturesLibraryEditor. |
Print at Oct 3, 2026, 1:38:22 AM |
| Posted by Keet at Mar 8, 2023, 2:26:04 PM |
Re: Regarding FurnitureLibraryEditor and TexturesLibraryEditor. Hi Puybaret, I found a bug with FurnitureLibraryEditor-1.31, when you import an item with the name followed by numbers at the end (eg chair_v_1.0) the last zero (0) is removed. It will then appear as (seat_v_1.) I ran into the same thing and reported it as a bug too some time ago. It's not only numbers but also things like a underscore. There's a little trick to get around this by abusing the fact that underscores are also removed: Add an underscore after the last number, i.e. 'chair_v_1.0' > 'chair_v_1.0_'. Since the underscore is removed the name with all numbers will remain. @Emmanuel The big question is Why? I can't imagine any reason to remove numbers or special characters. There can't be any invalid characters in the name because you can't export to such a name (the file system will reject it). At a minimum numbers should be allowed. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 3, 2026, 1:38:22 AM |
