Print at Sep 30, 2026, 9:30:48 AM
Posted by fma at Apr 27, 2010, 4:26:04 PM
Re: Écrire un plugin pour simuler l'éclairage de la course du soleil
Zut, apparemment je n'aurais pas du hésiter à écrire un rappel sur l'installation des plug-ins. wink
Les plug-ins sont abordés dans le guide d'utilsation
Je suis une buse : j'avais bien suivi ces explications, mais je regardais dans le mauvais menu (comme j'avais fait des tests de plugins sans traduction, les miens sont dans Tools, alors que le vrai menu c'est Outils !).
Mais ça ne marche pas :
Make sure it is located in the same server and directory with the model file. the loader's base path is: jar:file:/tmp/open1374584905366604351.sweethome3d!/29/
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.eteks.sweethome3d.plugin.advancedrendering.AdvancedPhotoPanel.displayView(Unknown Source)
at com.eteks.sweethome3d.plugin.advancedrendering.CreateAdvancedPhotoPlugin.createAdvancedPhotoPlugin(U
nknown Source)
at com.eteks.sweethome3d.plugin.advancedrendering.CreateAdvancedPhotoPlugin.access$000(Unknown Source)
at com.eteks.sweethome3d.plugin.advancedrendering.CreateAdvancedPhotoPlugin$1.execute(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane$ActionAdapter.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.menuDragMouseReleased(Unknown Source)
at javax.swing.JMenuItem.fireMenuDragMouseReleased(Unknown Source)
at javax.swing.JMenuItem.processMenuDragMouseEvent(Unknown Source)
at javax.swing.JMenuItem.processMouseEvent(Unknown Source)
at javax.swing.MenuSelectionManager.processMouseEvent(Unknown Source)
at javax.swing.plaf.basic.BasicPopupMenuUI$MouseGrabber.eventDispatched(Unknown Source)
at java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
at java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
at java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
nknown Source)
Frédéric
