Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: When adjusting wall thickness, make it possible to select in which direction the wall should expand » » » » Post: Re: When adjusting wall thickness, make it possible to select in which direction the wall should expand |
Print at Sep 24, 2026, 11:06:48 AM |
| Posted by Keet at Apr 5, 2023, 10:49:59 AM |
Re: When adjusting wall thickness, make it possible to select in which direction the wall should expand Adding such options would make a mess of the wall options: it adds options rarely used, solving a problem that can be solved in other ways. If you create a room from the inner dimensions you probably also know the wall dimensions. It's easier to manipulate walls than a room so start with the walls, positioning them so the inner dimensions fit, and then fill in the room. If you really need to adjust the wall thickness without changing the inner dimensions I suggest you use the options to move a wall after adjusting the thickness. I think it's the AdvancedEdit plugin that offers a menu item for moving objects. If you increased the wall thickness with 10 you move it with 5. You can also move a wall by changing the X and Y coordinates in the Wall properties window. I you need to move a wall up or down adjust both Y coordinates, for left or right adjust both X coordinates. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 24, 2026, 11:06:48 AM |
