Print at Oct 3, 2026, 8:56:08 AM
Posted by Puybaret at Apr 13, 2023, 4:26:55 PM
Re: Materials List: Where/how is it stored. Can it be exported?
If you're a developer, you shouldn't have problems to read the Home.xml entry stored in a SH3D file (a SH3D file is just a ZIP file), then keep the information you want by parsing it with your own parser or transform it with a XSLT file.
The DTD of Home.xml entry is available at https://www.sweethome3d.com/SweetHome3D.dtd and you'll see that furniture materials, textures and colors can be easily be identified. I would suggest to create a SH3D file using different type of colors / textures on walls and rooms, then look at its Home.xml entry to find the information you want.
