Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: making walls invissible » » » » Post: Re: making walls invisible/transparent part2 |
Print at Sep 30, 2026, 12:25:38 AM |
| Posted by DerekvG at May 14, 2023, 4:58:48 PM |
Re: making walls invisible/transparent part2 The 3D view modification pane lets you change the transparency of the walls. This makes all the walls transparent, the other way is to change the height of the wall in Ctrl-shift-E modify wall would it be a suggestion to be able to select a wall and make it transparent such that the user can work on the other walls furniture inside? |
Current timezone is GMT Sep 30, 2026, 12:25:38 AM |
