Print at Oct 7, 2026, 10:38:52 AM
Posted by Keet at May 23, 2023, 5:59:52 PM
Re: Show Distance Between Objects?
To expand on the suggestion Emmanuel made: install the AutoDimensioning plugin. Add a level with the same elevation and make that the selected level (name it "Dimensions" or something like that). Use the AutoDimensioning plugin to add all dimensions.
You now have all dimensions on the 'Dimensions' level and you can hide/show that level as you need.
More info about the AutoDimensioning plugin here .
