Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D vision is semi-transparent » » » » Post: Re: 3D vision is semi-transparent |
Print at Sep 29, 2026, 3:17:41 PM |
| Posted by Puybaret at May 31, 2023, 8:40:27 PM |
Re: 3D vision is semi-transparent Then it could be a graphics driver error. Do you run Sweet Home 3D 32 or 64 bit (see About dialog)? If you use the 32 bit version, try the 64 bit version by running the installer again, and choose 64 bit architecture when prompted (or the opposite if you run the 64 bit version). By the way, very nice design! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 3:17:41 PM |
