Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: accurate measurements » » » » Post: Re: accurate measurements |
Print at Oct 5, 2026, 1:24:19 PM |
| Posted by DerekvG at Jun 9, 2023, 4:23:07 PM |
Re: accurate measurements Thanks I have the advanced editing tool installed my question is about a measurement that cannot be derived from the dimension of an object eg the measurement between 2 opposing walls across 2 rooms, where the is no single wall . If I read you correctly to create a particular measurement between two objects on the plan I would need to create an object either furniture or a room of that particular size, the create the dimension measurement from that and copy that into the design at the correct location ? |
Current timezone is GMT Oct 5, 2026, 1:24:19 PM |
