Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Lines and text to walls » » » » Post: Re: Lines and text to walls |
Print at Oct 4, 2026, 1:54:36 AM |
| Posted by Daniels118 at Jun 15, 2023, 6:32:32 AM |
Re: Lines and text to walls Text can be added using the text tool, then edit the text properties and set its orientation to vertical, then rotate and move the text to place it on the wall. For complex drawing you may find easier to use a drawing program and then import your drawing as a texture. You can place the texture on the face of a flattened box and put it on the wall. |
Current timezone is GMT Oct 4, 2026, 1:54:36 AM |
