Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Lines and text to walls » » » » Post: Re: Lines and text to walls |
Print at Oct 3, 2026, 3:21:20 PM |
| Posted by Keet at Jun 15, 2023, 7:49:50 AM |
Re: Lines and text to walls The rendered text from Sweethome3D has a low resolution resulting in very ragged letters. Looks good while in SH3D but after export/import it doesn't look the same. For text you should use a graphics program like GIMP to create an image of your text and use the image as a texture on your furniture/wall/floor. Create an image the size of the surface you want to apply it to. That way it's easy to create the text and it's position exactly like you want it too. It also allows using multiple colors or a fancy background. That also solves your problem to add lines with colors to your wall. You can use the box Daniels118 mentioned but you can also apply the image directly to the wall. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 3, 2026, 3:21:20 PM |
