Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Textures not importing » » » » Post: Re: Textures not importing |
Print at Sep 30, 2026, 7:03:52 AM |
| Posted by Keet at Jun 16, 2023, 9:26:24 PM |
Re: Textures not importing Are you sure you have the correct texture for the part that turns black? High quality is rendered differently (of course) and handles the texture differently (with reflection, light, etc). Try to set a different texture from Sweethome3D and see if the high quality render does better. If the result is the same the problem is in the model, if it is good the problem is the texture. Maybe you just selected the wrong image from the original texture set. Also check if changing the light setting makes a difference (switching off ceiling light). And you can try to switching between the sunflow and jafaray renderers. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 30, 2026, 7:03:52 AM |
