Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Fix My Wonky Corners » » » » Post: Re: Fix My Wonky Corners |
Print at Oct 4, 2026, 12:54:18 AM |
| Posted by Keet at Jun 17, 2023, 1:13:16 PM |
Re: Fix My Wonky Corners Are you sure that is a screenshot from Sweethome3D? Because it looks quite different from my install. What gave it aways is the "Make invisible" in the context menu. You can't make walls invisible in Sweethome3D. I don't think there is any context menu in Sweethome3D with "Make invisible". So I assume that is a context menu from a different program. I also don't see that two walls are selected. For your corner you should select the two thick walls to join (top left and vertical). In Sweethome3D of course. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 4, 2026, 12:54:18 AM |
