Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:36:31 AM |
| Posted by Daniels118 at Jun 19, 2023, 1:43:45 PM |
Re: Wirings plugin There is a difference in the way screen coordinates are handled depending on the Java runtime version, the behaviour changes starting from Java 1.9 and above. Please open Sweet Home 3D, go to the Help menu and select "About", then check the Java version and report it here. Also check if the behaviour changes by changing the display scaling factor (the procedure depends on the window manager, search the web if you don't know how). You may also try to run SH3D with a different Java runtime to see if this can solve the problem (for this you have to install Java by yourself and download the Sweet Home 3D executable jar). From my side I'm running on OpenJDK 11 on Windows, but I could try to reproduce the problem on Linux Mint+Cinnamon after I have more details. |
Current timezone is GMT Sep 23, 2026, 10:36:31 AM |
