Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Ceiling Height » » » » Post: Re: Ceiling Height |
Print at Oct 3, 2026, 4:35:12 AM |
| Posted by Keet at Jun 22, 2023, 10:22:09 PM |
Re: Ceiling Height The ceiling is part of the room, not the walls. With the sloping walls you have the surrounding for the room. Add a room by double clicking the space inside the walls (must be an enclosed space). With a sloping wall you will probable select to display no ceiling but (room property) but choose to show the underside of the roof you add. The ceiling of a room is usually when you have a floor above. How you create a roof depends on what you need. You can use the Roof Generator (excellent plugin!) or simply use a box that you resize to fit and tilt in position. You can create a beam with a box by resizing and elevating it. You can even tily/rotate the beam if necessary. Always look at 'Modify ...' in the context menu (right click) for any object you want to manipulate, be it walls, rooms, or furniture. There you can see what you can change for that specific object. You should really read through the User's Guide and FAQ to understand the basics. It will make it much easier and enjoyable! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 3, 2026, 4:35:12 AM |
