Print at Sep 30, 2026, 8:33:32 AM
Posted by Keet at Jun 26, 2023, 4:04:34 PM
Re: Faces of the wall
I'd like to extend on that feature wish, one I have on my very long list of wishes smile
When exporting a wall we get 6 faces in the export, Left start-side, left, left end-side and the same three for the right side. By editing the obj file you can get 6 different properties but it's no longer a wall when you import it. For a wall I'd like to see 8 properties similar to the properties of a box: leftstart, left, leftend, rightstart, right, rightend, top, bottom. That way we can texture each face while the object remains a wall. This will also solve the problem with the distorted textures on the wall ends. With a separate property you can adjust it for just the ends so it looks right. The separate top and bottom are especially usefull when you use a wall to create a part for custom furniture and it gives the possibility to make each face invisible.
Separating the properties might be necessary anyway if the wish from crackwood01 is implemented.
I never used baseboards but I would have expected the default behaviour with baseboards to include the sides.
