Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Import Furniture Problem » » » » Post: Re: Import Furniture Problem |
Print at Oct 2, 2026, 4:31:48 PM |
| Posted by Keet at Jun 27, 2023, 8:57:22 AM |
Re: Import Furniture Problem If you have your model as obj/mtl on your computer you can use the file manager and just drap&drop the obj file in the 2D window. That's the way I mostly import furniture, I find it much easier with the huge benefit that the furniture is imported at the position where you drop it. You can even select multiple obj files and drag&drop them in the 2D window and they will each show the import dialog one after the other ![]() ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 4:31:48 PM |
