Print at Sep 28, 2026, 2:31:45 PM
Posted by Keet at Jul 1, 2023, 6:21:50 PM
Re: Textures attached to boxes sometimes stuck at 45 deg angle
If you can assign a texture to each side individually you can select the 'wrong' side and rotate the texture to fit.
If that doesn't work you will have to change your object in FreeCAD to make sure the texture is aligned correctly, which is probably the reason for the problem.
