Print at Sep 27, 2026, 4:21:44 PM
Posted by selden at Jul 3, 2023, 4:41:09 AM
Re: Object surfaces reflect environment?
I've made available a zip file which includes the files needed to reproduce my problem. Maybe it'll help someone to point out what I should be doing.
https://www.classe.cornell.edu/~seb/files/reflect.zip
(1.2 MB expands to 1.3 MB)
It contains the following files:
reflecting.png is a 1200x720 image rendered by SH3D showing the issue. The tall object is reflected in the top of the smaller object which is in front. The smaller object is reflected on the upper-inside of the taller one.
reflecting.sh3d is an SH3D project containing two furniture objects which reflect each other
sh3d_reflecting_screengrab.png is a screengrab showing SH3D (and its render settings) after it completed rendering the image.
TAMH_internal_stairs.mtl
TAMH_internal_stairs.obj
and
TAMH_long_room.mtl
TAMH_long_room.obj
are the two objects which reflect each other.
Selden
