Print at Oct 1, 2026, 4:29:08 AM
Posted by hansmex at Jul 9, 2023, 8:11:23 AM
Re: Objects not coloring correctly in render
This question has been asked before many times.
If you have a room with 4 white walls, probably none of these walls will appear perfectly white in your high quality renders. This has to do with the way light disperses, forms shadows, etc. Our eyes register white, but a computer shows shades a gray and/or bluish gray. Example, corners of a room will always appear darker, the wall next to the windows will appear darker than the wall opposite the windows.
Colours other than white may also show up in a way you don't like. Instead of using a "colour" you can use a texture of the desired colour. This generally gives a better result. Just search for a plain texture using the desired hex code.
Always use quality setting 3 or 4 if you want a (more or less) realistic render.
